sail cleaning and roller reefing
I won't be sailng my 76 c-22 til spring and have her stored some 5 miles away... yet I find I visit her everyday.
I have my motor and sail bag at home (to my wifes dismay) and noticed that my genoa and main are grey in color when compared to my apparently new jib. Is there any method, other than mild soap and water to restore them to more of their natural color?
Also, the idea of roller reefing for my jib and/or genoa intriges me since none of my previous boats have had this capability. Is there anywhere I can purchase one? If not, does anyone have plans to make one.
Thanks... Steve
Thanks... Steve
There are a ton of rollers you can adapt to your boat. Keep in mind that normally a roller gib will loose it shape when roller more then 10 percent in, so the sail will not be as efficient as your normal hank on sail. I am not sure that is really an issue with a cruiser. With that being said it is so nice to be able to reef it in instead of changing out the sail
Hi Gus. I was concerned because a fella at the marina told me that Dacron sails have some compound sandwiched between two outer layers of Dacron fabric. And according to him, you don't want to disturb this middle layer. I've been sailing for 40 plus years, and this was the first I'd heard about it. I just wanted to make sure I don't make things worse.
I'll give your method a shot... then afterwards, perhaps make some wine.
Thanks... Steve
Thanks... Steve
- STEVE ROYER
ROLLER REEFING
I HAVE A CDI FLEXABLE FURLER FF6 I SALVAGED FROM MY EASTERLY 31FT
THAT I LOST IN HURICANE KATRINA AND IM GOING TO INSTALL IT ON MY C-26 ,THERE NOT VERY EXPENSIVE AND ITS ALL PVC SO YOU DONT HAVE TO WORRY ABOUT BENT EXTRUSIONS WHEN RAISING & LOWERING THE MAST THERE ARE SMALLER SIZES
- STEVE ROYER
- STEVE ROYER
Tell me about it. I figure the wife is going to shoot me, because I need a spare tire and rim, two batteries to run my electric system including the electric start engine, lighting system, and marine radio (which I still don't have), a couple of 13 lb anchors, chains, rodes, etc... On top of that, I have my eye on a C26 that a fellow at the marina seems motivated to sell. Yep, I'm dead!
Steve
Steve
