Rats, I am going to be the contratian here on this one. Yup I'm tossing in my $2.00 again... that's $0.02 cents adjusted for inflation and in a boating context which always costs more as we all know.
So take it from that perspective. I'm not trying to talk you out of it, just giving a different view point.
I hate my outboard remote control. I have stubbed my toes way more times then I can remember. I've gotten lines fowled on it many times as will. It sticks out in all the wrong ways. I will have it out before I sail again this season.
Oh yea one other big issue I have with the remote control. I pull my motor off my boat 100% of the time when not in use. All the control cables are a real pain. My 2 cycle is heavy enough to lift on and off the boat much less the control cables too. Arrg, that's why Pirates make that noise, Arrg, because something was way more complicated then it needed to be and you can't print what they really said as that would not be genteel.
I steer with my rudder only so I want my motor locked 90 degrees to the stern. Shifting forward and revers, I just slow the motor down with the rotating throttle which sticks up nicely from my motor and I move the lever backward or forward or neutral. Easy peachy keen! No Arrg here.
Okay an electric start and a generator/alternator/dynamo would be WAY cool and I'd be front and center for those. Just a cable going to my battery and a starter switch and a kill switch. All you would have to do is unplug your electrical connectors and you can take the motor right off. Easy peachy keen! No Arrg here either.
I try and subscribe to the K.I.S.S. (Keep. It. Simple. Silly.) principle when ever possible... Or when someone here on the forum says, "Wow why don't you do it this way instead." and then I rethink my Rube Goldberg inspired designed mouse trap thing-a-majig I've been working on and do it K.I.S.S.
Hey speaking of "Arrg" when is National Speak like a Pirate day coming up again? We need to have a good showing here that day so we can plan ahead.
