the rudder has a number of dings down its side.
This side does not look that bad.
In this pic you see the cut out and center disk, witch all but fall out on pulling rudder.
The center disk itself.
The center disk with blots.
I hope in the end I can save this rudder blade. the way I see it the seven bolt system looks to be stroung. The bolts hold the center disk in place while the rudder moves around the disk not just a single bolt.
Chrysler 26 1980
