Replacement plywood
Post All Paint, Fiberglass, Or Maintenance Topics Here.
Gary w/C26 & LS13
Replacement plywood
Postby Gary w/C26 & LS13 » Fri Nov 12, 2021 3:02 pm
The plywood that is the rear berth in my C26 must be replaced. Along with the underside of the cockpit sole. Assuming I stop the cockpit leak - does anyone know if these areas were originally built using exterior grade or marine grade plywood?
I’d like to use exterior grade for cost savings. Any suggestions?
Return to “Paints/Fiberglass/Maintenance”
Users browsing this forum: No registered users and 3 guests
