Wiring diagram?
amecum
Wiring diagram?
Postby amecum » Mon Mar 23, 2015 10:22 am
I just bought a c26 fixed keel. Im stoked shes rough but in sound shape. however there has been a stripping of all electronics from it. thank god they left the mast alone. but I was wondering if anyone had a diagram for what its supposed to be or maybe a few ideas of what to do.
thanks
the water belongs outside.
Postby CaptainScott » Mon Mar 23, 2015 11:57 am
Welcome to the forum!
I'm not aware of any wiring diagrams, maybe one of the 26 owners can pipe in!
Again, Welcome!
mcrandall
C Shirt
C Shirt
Postby mcrandall » Mon Mar 23, 2015 4:14 pm
I'm now an owner of both the C-22 you see on my avatar and a well stripped C-26 once owned by our friend Sauerleigh.
The way I see it, that's the perfect time to set your boat up with just what you want. Get into a book or two to keep you out of trouble. Don Casey and Nigel Calder are a couple favorites, but there are many. It doesn't have to be elaborate, just safe.
Good luck!
Postby EmergencyExit » Wed Mar 25, 2015 5:31 am
Welcome aboard !
I've never seen a factory diagram, but the C26 didn't appear to come with much more than a battery feeding a fuse box, the nav lights, 4 cabin lights (stern berth, cabin, head, and vberth). The cabin lights had their own switch so they didn't go thru a power panel, The nav lights on EE were just a single toggle switch after the fuse box, and that was about it.
If it helps, I can tell you that on EE the wiring for the bow lights runs under the port banquette into a pipe that carries them thru to the bow. The wires for the head and vberth lights go along the port banquette, then turn under the head, then run up a corner trim piece near the mast step, then thru a trim piece above the head doorway.
Wasn't much there originally...
darmah
2016 update?
Postby darmah » Sun Feb 14, 2016 9:16 am
Still no one with an OEM wiring schematic?
Even a modified system? My acquisition has an original distribution panel below the galley as well as one starboard inside the companion way with operational switches for running, cabin, bilge and several acc. Switches.
Tb or not tb
Return to “Electrical”
Users browsing this forum: No registered users and 3 guests
