Privateer
Privateer
Hi , I’m a new owner of a privateer. The boom block that attaches to the track on the underside of the boom is missing. Part # 25146. is this available or what is a substitute? There’s a number of things misrigged that I’m sorting out. How is the rudder designed to be rigged? Not sure if I understand correctly how it is supposed to function. Any help would be greatly appreciated. Thanks. Bill
Re: Privateer
Bill,
I have no experience with the privateer but I checked in the document section where all the Chrysler manuals are. The Privateer Manuel is there and has quite a bit of information along with some photos that should hep with proper rigging . As far as parts go you will likely just have to look at the pictures and find something that will work. I wouldn’t think you will have too much trouble.
Welcome to the forum!
Rick SVBrigadoon
Rick SVBrigadoon
Re: Privateer
I've ordered this one
Barton Size 3 Fiddle Swivel w/ Becket & Plastic Cam - #N03731
I'll let you know how it works out
Re: Privateer
So, it may have been the least expensive, but it was still huge!
Sadly, the boom block isn't removable, not without removing rivets, not something I wanted to do.
So I took drastic measures and customized my pirateer.
